I get an error when receiving NC Drill output
CORTEX , 08-09-2019, 01:13 AM
I did the 6-layer pcb design and I get the error when I want to print the hole, why can the problem be caused ?
Access violation at address 0000000183DE123F in module 'OUT_Drill.dll'. Read of address 0000002400000000 at 0000000183DE123F.
robertferanec , 08-12-2019, 04:23 AM
I am sorry, there is not really much how to help. What sometimes help is switch off Altium and start it again. But often Altium errors are caused by something in files.
CORTEX , 08-13-2019, 03:18 AM
Thanks Robert Problem solved
The reason for the problem is in this link :
https://electronics.stackexchange.co...iolation-errorThere was a problem with the heap manager, via the library, or from related publications, as indicated, the TH connector failed.
I used footprint from the Eagle library. that's the problem.
Pad problem is fixed I recreated TH.
robertferanec , 08-13-2019, 02:40 PM
Thank you for letting me know.
