Where is the Pullback column in Altium 19+?
gmezzina23 , 01-13-2020, 09:59 AM
Hey there,
I used to use the Pullback column in Layer Stackup manager for Altium <19.0.
Does someone know where I can found the same functionality in Altium 19 +?
I cannot found an equivalent command in the newer versions
Explore Altium Designer 18.1 technical documentation for PCB_Dlg-LayerStackManagerLayer Stack Manager_AD and related features.
It seems that the Pullback function is active up to the 18.1 version
Sincerely,
GM
MrSun , 01-13-2020, 10:54 PM
hello @gmezzina23 in Altium 19,pullback function is in "Layer Stack Manager"
Lakshamana Balakrishnan , 11-19-2021, 04:37 AM
Hey Guys, Pullback distance how it helps? Can you explain the usage of that option? @MrSun
WhoKnewKnows , 11-19-2021, 07:02 PM
Typically, when PCBs are cut from their "mother" panel, it's best, for a variety of reasons, to not have copper on the PCB where the cutting tool goes through the PCB to free it. So we "pull the copper back" from the PCB edge to keep it out of the way of the tooling.
Lakshamana Balakrishnan , 11-19-2021, 08:59 PM
@WhoKnewKnows yes now i am cleared hope this option for Plane layer only. Thanks for the support
