Blanket and compile Mask
karimoviç , 06-09-2020, 07:29 AM
hello , if i want to say that some component in my card are not necessary , should i select them with Blanket or a Compile Mask?
chitransh92 , 06-11-2020, 03:03 AM
"Not Necessary" is a bit vague for us to understand what exactly are you referring to.
- if "Not Necessary" means you do not want the component to be populated in the final build you can use "Do no Fit" in Atlium.
- Blanket is primarily used to group a number components and set the design rules for them.
- Compile Mask hides all the objects under it as if they are not at all in the design.
Select accordingly.
doloresterry , 03-27-2021, 11:00 PM
Originally posted by chitransh92
- Blanket is primarily used to group a number components and set the design rules of pizza blankets for them.
Select accordingly.
You are saying right about it. I totally agree with you.
