JohnsonMiller , 01-18-2021, 12:34 AM
@WhoKnewKnows , thank you for your suggestion, I am testing with AD21.0.9, but no success!
I did a test with AD's own flex-rigid sample design, same problem shows up.
I also create a fresh and simple design, it works but not movement is not smooth as AD17.
So my conclusion, looks command is changed from AD17 to AD20/21.
Good news, is that a 3D view is added for stack up editor,
AD17 shows stack up in the continuous form, i.e., different stack up next to each other. In AD21 it is changed to single view, you have to switch between them to set parameters. Personally, I feel AD17 way was more helpful and productive. Any help to change AD21 back to AD17 visual form?
