JohnsonMiller , 01-30-2022, 05:06 AM
@robertferanec , I was using this feature for a long time after learning it from your videos, and it was very helpful in PCB placements,
The strange thing that is happening is new, for your reference AD 22.1.2.
Point is that, after setting cross-select, when you select an item in PCB it highlights it in the schematic, and vice versa, which is ok. But if you hit Delete, it first deletes the highlighted element in the schematic then you have to hit Delete again to delete the item from the main PCB documents.
For example, if you select a trace in the routed PCB, and hit delete to un-route it. You have to hit Delete twice, it deletes the net from the schematic!!! and rhen un-route PCB. In other words, the schematic is destroyed!
The reverse also happens, if you want to delete a net in the schematic, again have to hit Delete twice and it un-route and delete the net from PCB fully, as well! PCB is destroyed.
My board was a big one, with lots of polygons and nets, I was editing the schematic but I noticed PCB is disappearing gradually with each Delete hit, unfortunately was quite late lost 3 days of work.
