qdrives , 11-26-2023, 01:03 PM
1) My tips:
- Set the grid to a large value (>= 1mm)
- Draw on a mechanical layer the board outline you want. Name this layer the board outline layer. I use mechanical layer for this, but it is up to you which one you choose.
- (In single layer mode) select all the lines and then Design / Board shape / Define board shape from selected objects.
2) Sure, see also point 1.
2a) ...Turns all green (screenshot 2)... --> you have 'removed' the board. If the cut-out has the same shape as the board, you effectively removed the entire board.
2b) Use the Define board shape from selected objects action.
3) No, you do not need to redo nets (track, arcs, etc.) that are ok. But if there are nets that have a short circuit, you have to remove one of the tracks and fix the connection.
4) You might have "drag" enabled for component movement. I do not as Altium creates such shorts. I cannot help you on fixing them as I have too little information about it. The violation will state something like "track on layer x to via". Also make sure that when you double click on the violation that the zoom factor is good enough to be at the location (not to far out / in).
5) See point 4.
When working on the board, just have the top, bottom and top legend layers visible. None of the other layers matter at this time.
