robertferanec , 07-09-2016, 07:54 PM
Hi Lorien, I intentionally avoid using components from suppliers different than Digikey, Farnell or Mouser. From my experience, if I select components from these, it's simple to build prototypes (to buy small quantities), delivery time is ok and we do not have problems to source the components. In past I used to buy from many different suppliers and we kept having a lot of issues (impossible to buy, 16 weeks delivery time, minimum order quantity 1500pcs, ....), so I just do not use components in my design which can not be sourced within these three big component suppliers.
So, to answer your question, I would probably do it exactly the same way as you did - just add the parameters which you use in BOM template. I think, the price can be even specified for different quantities like "1=0.39, 10=0.354, 25=0.2548, 100=0.1983, 250=0.12456, 500=0.10616, 1000=0.07233 (USD)", and it should work, but I have not tried it, so I do not really know.
I use the Digikey Parameters as the reference - as that is our main supplier and most of the components is sourced from them.
