Hi all.
I don´t know how set a rule to realize the way of nets in a determinated area like a perimeter of a component for example I see the rule, in the video
When you are doing layout, sometimes you may want to use a special rule in a specific area, for example if you have a BGA with a very small pitch, which requ...
but this only works if only this rule is the one.
For example in my pcb the first rule is a clarance all-all 12 mil and then all nets are marking with violation around the component but because between it`s pad the distance is 7mil.
Then I apply the rule of video but this violations not disappears. I been searching and I found something like a define a room but I don´t understand then, how link this in the query of the clearance rules, I need some rule like a area where allow a clearance < 12 mil. I don´t know how to do that. Some idea for this problem? Thanks
