mairomaster , 09-30-2016, 01:44 AM
Hi @JohnsonMiller,
If you are using Altium planes, those are negative layers so you can just use normal polygons for the cutout (since positive copper shapes like polygons, fills, regions, tracks, etc. create a cutout on a negative layers). I am not sure what will happen if you use polygon cutout on a plane layer, you can test it with a dummy PCB by exporting gerber files and checking what happens.
If you are using signal layers and big polygons for your planes, then you can use polygon cutouts.
