JohnsonMiller , 10-21-2016, 02:23 AM
Hi Guys,
Ordering a solder paste stencil, I got some issues and questions, would appreciate you time if you take a look and give answers:
- We ordered .125mm or 125um thickness stencil as recommended, but looks that with 125um thickness amount of paste on pad is not enough, since board will need to pass some vibration test. So there is some fear that components will not stand vibration. What is solution, should we order thicker stencil? or change pate?
- In ordered stencil, when you look at pad shape especially big components like D case tantalum caps, it is clear that pad shape is changed by adding a small triangular to inner side, what is reason to do this sort of modifications? attached is a sample photo,
I would like to pad shape change and we asked them to do so, but result is different? Is there any IPC standards (or part of it) defining stencils?
- In designs with different variant, what happens to stencil, different stencil per variant? I need DNP components with no pate on pad, any suggestion?
- In general, what design rules we should obey to make a design pick-and-place machine friendly?
- Regarding angel by which trace enters pad, is there any recommendation or limit which may affect assembly or test?
