JimS , 12-17-2016, 01:11 PM
Hello All,
I have a MySql Db, populated and working,,,,, mostly. I find that I cannot use the Filter line in the Library pane when trying to add a component to a schematic. Anything typed into the Filter line is ignored. However, if I point at a flat library (SchLib) the filter works just fine. Is there a specific column needed in my Db tables? Flat libraries have a Column name called "Component Name", my Db does not contain this column, I did manually add it to one of my tables and placed a copy of what is in the Library Ref fields into it, but still no filter operation.
I have watched my network traffic using Wireshark, capturing the MySql packets and find only this vague message repeated numbers of times. "Expert Info (Warning/Undecoded): FIXME - dissector is incomplete." If I don't attempt using the filter, I have no errors or other issues. So I feel my connection scheme is fine.
I feel that a required field is not present in the Db, that the Filter is looking for.
I have found little at Altium that explains what are required fields for a Db, and no help regarding the use of MySql. I have also opened a service call on this subject with Altium support, but have not gotten any feedback as of yet. Thought I would look around and found this forum. There seems to be some knowledge here. Any ideas anyone?
TIA,
Jim
