robertferanec , 10-21-2015, 12:42 AM
Couple of options:
- use the same chip but in different package
- use more expensive PCB - smaller tracks or VIA in pad
- talk to your PCB manufacturer. Some of them may be able to use cheap technology and make a few exceptions - to use couple of tracks thinner as they normally use for that technology, but it only can be in one small PCB area.
It looks like, the package you use is designed the way you can connect the pads together - only the C4 VIN seems to be in a weird position. Is not possible to connect C4 to one of the pads what are close to it?
Also, in some cases you can find a demo board (where the chip is used) and you can check how they did that.
