JohnsonMiller , 01-12-2017, 01:38 PM
" what makes you believe that?"
Reason is the library system that I am currently using, I am not allowed to change any field in components. So that for the mentioned task, SCH to PCB link is actually broken.
Yes, once we had similar discussion, that I was about to fix this issue using supplier link and it failed in BOM generation.
That time, the descriptor field was out of sync, and silkscreen issue was there as well.
The reason I bring this issue forward is some design in which I saw statement specifying some text and asking PCB designer to put it on silkscreen layer, I tought probably we can do it by using project parameter by setting it for PCB and schematics.
I have also used your proposed method, but problem is possibility of forgetting to update in PCB,
BR,
