JohnsonMiller , 02-23-2017, 06:06 AM
Hi Guys,
In multi-layer boards sometime we need to cut plane layer or use different polygons, it may happen that a via sits in separation area and cause manufacturing issue, following is an example which happened for me recently.
the VCC3V3 net is bottom side of figure so there was connection between via and plane, and it was reason that Altium did not report any violation, however after manufacturing we see e-test failure and has to re-manufacture the board.
My question is "do we have some design rule or any other means to find out vias which is placed in void area? or find out vias which do not have proper connection?"
BR,
