Maybe it was accidentally moved as a PAD and not as a component? Always when this kind of component is moved, be sure that when you select it, you can see SQUARE. If you do not see SQUARE, it means only pad is selected (and only pad is moved, not the component).
To correct this, write down the pad position (double click on the pad), write down the component position (double click on the pad the way you see the SQUARE) and correct it (move the pad into position where the component is and then move the component into position where pad was). It sounds complicated, but you will understand
