jaguarondi , 08-06-2017, 01:48 AM
Hello everyone,
I have an FPC connector for an LCD. The FPC is bent back below the LCD where the connector is. In that configuration, I have to use a bottom contact FPC connector but I end-up having pin 1 of the cable connected to pin 50 of the FPC connector.
Being new to PCB design, I just wonder what's the proper way to handle this, should I reverse the connections on the schematic or have another footprint where all pins are reversed ?
Thank you for your suggestions,
David
