violations error
harish , 05-30-2024, 05:14 AM
Hi Guys , while doing layout , I came across clearance error as shown below . can anyone pls tell me how to avoid this error.
Thanks in adavance
Robert Feranec , 05-30-2024, 06:18 AM
Click on Panels (bottom right corner) -> PCB Rules and Violations. Double click on them, it will tell you exactly what the problem is. This video may help: https://www.youtube.com/watch?v=f7GP6NZs0Ok&t=1862s
harish , 05-30-2024, 07:27 AM
Hi @Robert Feranec by following youtube videos i did the same but still it gettting errors shown below
harish , 05-30-2024, 07:49 AM
Arkev , 05-30-2024, 10:48 AM
Everything should be said in the message, read it completely
You've got a collision between an arc and something else
There are many possible issues
Arkev , 05-30-2024, 10:49 AM
Since you also have collisions in components that are not routed yet, I'd say your footprints might be the problem
Robert Feranec , 05-30-2024, 11:16 AM
Exactly as @Arkev pointed out - the problem will be described in the message. From your screenshots it is not clear what the error is. Did you try the PCB Rules and Violations panel and read all the messages? E.g. hover over the error and read it completely, possibly double click on the error and read what DRC is causing the problem and between which objects.
QDrives , 05-30-2024, 03:33 PM
Are you sure those pins need to be connected?
If you remove some track, will a ratsnest appear connecting the track ends?
Next time use alt-prtscn to capture the screen and do not make a photo with your phone. Things are not so clear with the phone.
Alternatively use the "snipping tool" or install something more powerful like "greenshot".
QDrives , 05-30-2024, 03:39 PM
Your clearance rule is not correct. It is set to "any net" and should be "different nets only".
harish , 06-01-2024, 04:51 AM
Thanks for all I got it .
