Nick.T , 05-27-2025, 04:22 PM
@Phil  Hi Phill, I am currently creating my version of the board for the course and want to use USB PD to power the board instead of a barrel Jack.    Seem straightforward enough I had a question about the VCC is being tied to the USB MicroB and the barrel jacks via the diodes.  Doesn't this mean that if the barrel jack is not connect and the usb cable is plugged in the board will try to power up from the microB USB which may not provide enough current (limited to 500mA or 1A or the like)  Wouldn't this present a problem and perhaps the efuse should be prevented from switching on when only the microB USB is connected or similar or did you not encounter a problem with this?
