Dear Robert,
Hi, this issue is related to a custom board implemented based around IMX6-Rex board.
> After running DDR Calibration (using V2.6) for many times, I obtained a bit consistent MMDC register values.
> And these values were accordingly updated in the .cfg file (800mhz_4x256mx16.cfg). This cfg is used to source RAM configurations to the u-boot (2016) we run.
> After adding
only these updated configurations, I compiled the u-boot and successfully loaded it to spi flash.
> On the OS (I use ubuntu xenial,
booting from a SD card), ran StressTest for 30 minutes, and the log I got can be seen in following link :
As you can see, there were 5 HW errors reported. So my questions are,
1. Can we decode these error messages and exactly interpret where the issues were ?
2. Apart from the changes made in .cfg file, is there any other setting I have to make ?
3. Since I am running ubuntu on SD card, could this be due to SD card defects ?
Thanks in Advance
Anuradha
