Understanding of the Single ended to 'balanced' converter
Enginstud , 05-09-2023, 11:51 AM
Hi everyone,
I need help with understanding the schematic used in the course before feeding our single ended biased signal to the ADC differential inputs.
VCOM is the biasing voltage.
I understood that r306 and C307 form a low pass filter, but why not connecting the cap to GND ? I believe it has to do with the "balanced" conversion, we want the same common mode voltage on both lines I think, but it's still obscur to me.
Can you please help me understanding that circuit? I searched online but did not find responses.
And, what if we did not used that circuit, and directly connected the biased voltage to -IN, and the biased signal to +in of the ADC ?
Thank you very much.
qdrives , 05-09-2023, 02:41 PM
R306 and C307 alone are not a low pass filter.
You can consider R307 at as being in series with R306 for that filter and then the question is how low impedance is Vcom?
If you want a more direct low pass filter, C307 need to be connected to Gnd.
As it is now, when ADC_IN+ goes up, so does ADC_IN-, until R307 can lower it back to Vcom.
This also is not a differential signal as ADC_IN- is almost constant at Vcom. Transients on ADC_IN+ are the same polarity on ADC_IN- due to C307 as mentioned before.
Enginstud , 05-10-2023, 02:15 PM
To understand that subject I'll need more explanation, can you maybe redirect me to ressources on that subject ? I searched but did not find enough explanation on that, I am a still a beginner regarding analog stuff, I need to learn more.
qdrives , 05-11-2023, 03:37 PM
"...that subject..." I assume you mean the RC filter?
Well, you would need to start there ("RC filter") together with the basic circuit elements resistors and capacitors in this case.
