SATA hard drive on PCB
altay , 05-17-2019, 02:14 PM
I have to add a 2.5" SATA hard disk to my circuit. I have two questions:
1- How to mount the HDD to my PCB? Is there any standard cage for mounting SATA disk on PCB?
2- is it safe or good to mount the disk just under the CPU or micro chip?
Thanks
Paul van Avesaath , 05-18-2019, 01:14 PM
yes there is a guidline out there.. just google for 2.5" ssd mounting holes.. there should be a lot of info on google...
just put holes in the pcb.. and screw it down.. there should be some cages i guess.. but most of the time they just bolt them down on the pcb.
if you want a bracket for it.. best thing to do is buy them and make them work with your design..
i would not reccommend putting a ssd on the bottom side of the CPU.. the heat dissipation of a CPU can cause issues.. not for the ssd mind you but more for the CPU..
Lakshmi , 05-20-2019, 04:24 AM
Rather you could use a connector SATA Connector and connect your SSD.
SATA has 7 Data Pins and 15 Power Pins. Check SATA Version before using.
robertferanec , 05-20-2019, 07:03 AM
Once, someone wanted to help us with SATA for OpenRex, He has never finish it, but it can give you an idea how to do it. Here are the files: https://github.com/hemalchevli/openrex-hdd-add-on
PS: You may not be able to mount anything under CPU as there will be probably components (unless you find a stand off solution - but still as @Paul van Avesaath mentioned, you need to be careful about heat dissipation).
PSS: There are also different solutions, e.g. have a look here: https://www.imx6rex.com/2017/09/sata...or-rex-boards/
3D PDF is in attachment, here is screenshot from the 3D pdf:
