robertferanec , 08-16-2019, 08:57 AM
This is what I normally use:
- Schematic libraries: 100mils (I do use smaller grid, but only to draw graphical elements inside of the symbol)
- Schematic: 100mils, sometimes I go for 50mils (if schematic is very complex or if reference design is using 50mils)
Note: General advise: do not change default grids in schematic, it can cause a LOT of problems (especially in compatibility with other projects - eg. if you need to import reference designs)
- Footprints: default mm, however if component is designed in mils or datasheet is in mils, I can create the footprint in mils
- PCB: Depends on project and customer, especially if shape and position of key components (e.g. mounting holes) is defined in mm or mil. If customer is from US, usually the board is designed in mils, but most of my PCBs are in mm with mixed footprints (created in mm and also mils).
