robertferanec , 11-18-2019, 09:45 AM
I checked, they have CASE_GND connected only locally under the Ethernet.
But, you are right,, if you are using CASE_GND you may want to connect there also other things like mounting holes or shield of other connectors. And yes it helps with ESD.
