DDR3 routing (with xilinx zynq chip as driver)
luigi , 03-26-2020, 07:34 AM
Board setup:
XC7Z020-1CLG400C zyng as driver
IS43TR16256A-125KBL as DDR3
1.
Question:
What is better to routing (ADDRESS + CONTROL) signals
a. Some in one layer (with tracks only in this layer) and some others in an other signal layer (with tracks only in this layer);
Example
PIN1 -> VIA -> L3 -> VIA -> PIN2
PIN3 -> VIA -> L8 -> VIA -> PIN4
b. In 2 layer with track segment in both layer;
Example
PIN -> VIA -> L3 -> VIA -> L8 -> VIA -> PIN;
all lines routed in this way.
Thanks a lot
robertferanec , 03-27-2020, 06:24 AM
b is safer (that is also what I prefer to use). In some cases we do route add/cmd/ctl signals on different layers, but then you need to know what you are doing - you need to be careful about proper length matching.
luigi , 04-01-2020, 01:10 AM
before all thanks a lot Robert.
I'm routing ADDR/CMD/CNTR tracks group.
How much has to be the difference lenght between track in this group, before tuning?
In my routing I have 20 mm difference between longer track and shorter. In this way I have to use big space to tunning tracks.
Is it right or I have to change the base routing?
Thanks
robertferanec , 04-02-2020, 06:43 AM
I usually have three phases:
1) connect - in this phase, there may be big difference between tracks, still, be sure difference is not too big as it may be very difficult to add a lot of length on many signals.
2) do approximate length matching (almost the right length, but not spending too much time playing with it) - often I make the tracks a little bit longer as it is simple to make them shorter
3) fine tuning (final length matching and locking down the tracks) - adjusting the tracks to the target length.
So it depends in what phase of design you are ... in phase 1 you may have 20mm difference.
luigi , 04-02-2020, 07:32 AM
I'm in first phase.
Thanks a lot
Luigi
