Is the current flow on power plane always incudes output capacitors and it filtering power correctly ?
Yes, the current flow on the power plane always include at least one capacitor and there could be more as per requirement.
There are 2 application of the capacitors i.,e Decoupling and Bypass..
Decoupling Caps are used to provide low impedance source of energy to High frequency change in load current. These are comparatively high value caps and typical values 1uF, 4.7uF, 10uF, 22uF..
Bypass caps are used to provide a low impedance path to the high frequency noise signals.These are low values caps Typical values 100nF, 680nF etc.
Your application may require utilization of either of these or both in conjunction with each other and this solely depends on your application.
For this eval board, C1,C4 are bypass caps and C2. C3. C5, C6 are decoupling caps.
At times these function as both depending on frequency...
Thanks..
