1) Why all the vias?
2) 8A with 35um copper (1oz) on a 12mm wide track will cause 10 degrees C temperature rise (source
https://saturnpcb.com/saturn-pcb-toolkit/)
3) Clearance for the 220Vac to secondary must be at least 6mm (Europe) and, as far as I know, more for UL (USA).
4) Clearance for 220V between line and neutral needs to be bigger.
5) Why the Normally Closed contact? Of that is not as capable for current compared to the normally open one.
6) The schematic of the mains connectors (IEC320 C13) shows 3 pins, whereas the PCB layout has 4. Two pairs, with each pair being shorted.
7) It also seems that the Line and Neutral are swapped between input and output.
8) Why the opto-coupler? Supply (signal) driving the input is connected to the output (Gnd and +5V0).
And yes, a two layer board would be ok here.
