binayak , 06-06-2023, 08:57 PM
Bermell,
You can't randomly choose dielectric constant and dielectric thicknesses of cores and prepregs to get controlled-impedance stackup. You need to cross check whether there is material available in the market that matches your requirements.
Otherwise, you will create a great stackup in the tool, but won't be able to manufacture it!
In addition, if it's a high speed board with signal integrity involved, and if you change dielectric constant, dissipation factor, dielectric thickness, etc. at the end due to the fabricator's recommendation (because you the stackup dimension you decided are not available in the market or with the fabricator), all of your signal integrity analysis work has become completely useless.
So it's always better to involve the PCB fabricator from the start, and create stackups based on actual material available to you in the market instead of some random values that give you controlled impedances.
Binayak
