Altium Footprints
IMR , 05-22-2016, 11:52 PM
I've been using the (tools > new part) to create multiple schematic symbols for an FPGA, the problem is when I add the the footprint for the FPGA it adds the footprint to each sub part. For example if I divided an FPGA into 3 sub parts IC1A, IC1B and IC1C it adds 3 component footprints to the the PCB. How can I add the footprint in the schematic library without this happening?
mairomaster , 05-23-2016, 01:50 AM
That shouldn't be happening, maybe you are doing something wrong or have the wrong understanding of it. When you create the schematic symbol with sub-parts, it represents a single component. When you add it to the schematic, you should have the same designator number on all sub-parts - as you said IC1A, IC1B and IC1C for example. When you double click on one of the sub-parts, in the properties should say Part 1/3 for example (first part out of 3).
If all of this is correct, when you import the design to a PCB file, you will have 1 footprint representing the component with designator IC1.
IMR , 05-23-2016, 05:07 AM
I just tried deleting it and putting it back in and it worked, not sure how it happened but it seems to be fine now.
