millensg , 12-10-2015, 06:43 AM
This is the first time I have used the Fedevel forum and I am already a customer of the Academy Video Course.
I am trying to modify an existing PCB Design using Altium, by making the board smaller and improving the fanout before going through EMC testing and certification. After I rotate the imx6 processor and the memory by 90 degrees, and moving the fucials and some of the capactiors/resistors, and it then says it is failing the Design Rules even though they have not changed. The Design rules are <3mm proximity and <10mm for vertical.
Existing Design:
(See attached image)(Design already routed)
As you can see there is no ‘Green’ components to indicate a Design Rule violation, but, when I re-organise below:
The Capacitors/resistors in the bottom right are causing a violation with the 200pin connector whilst the fudicals are causing a violation in close proximity the memory and to the iMX6 chip. This was not causing a problem before and it is now and I do not know why, or, how to correct it/ignore it.
Is anyone able to advise?
Many Thanks
Sam M
