dlo , 02-03-2019, 05:18 PM
What have you found to be the minimum component clearance for reliable high density designs? Right now I've managed to get boards made with 0.005" spacing. For example the distance between two 0201 capacitors is 5 mil apart. I've also been making them with 0.01" spacing from the edge of the board and it seems to be ok with the manufacturer. What has been your experience with component clearances and clearance from board edge?
