Am I doing SPI connections and stitching vias correctly?
Astral Master , 11-15-2025, 09:35 AM
SPI trace length < 9mmSPI Via size 0.3mm x 0.6mmStitching Ground Via Size 0.2mm x 0.4mmI'm estimating .5ns or 500ps rise time Frequency estimate 2-3 GHZI did the best I can I don't know if there is something I could be doing better. I would like to reduce noise as much as possible.very sensitive EEG signal electrode traces 10H distance away. 10H = 10x distance from spi trace to ground plane.I heard Rick Hartley say 20H was necessary
QDrives , 11-15-2025, 04:44 PM
Why the two different sizes in vias?What makes you think the rise time is 500ps?What data rates do you need?If noise is important, why not add a series terminating resistor as well?
Astral Master , 11-16-2025, 06:13 AM
I need about 40kb/s. The ads1299 ibis model said 500ps I will be adding 22 ohm series resistors and the different via sizes are because those small ones are stitching vias
QDrives , 11-16-2025, 05:15 PM
So slow.https://www.tina.com/ibis-simulation/But why have bigger vias?
Astral Master , 11-17-2025, 09:34 AM
i dont understand why have bigger vias? and yea its eeg so i only really nees 500 sps at 24 bits so ill be good
QDrives , 11-17-2025, 03:18 PM
For SI the best vias have a via barrel of 0.2mm.Do note that the pad size (often) needs to be bigger to comply to the annular ring rules (>= 0.15mm).
