Board to Board Connector
sheldor , 05-24-2024, 02:36 PM
Hello, I'm a new designer and I am designing a system. I need 2 different cards for the system. I need to connect 2 pcb's with a board to board connector. I tried DF9 but it doesn't look very reliable since the system sometimes need to work under vibration, shock etc. sometimes. Do you have any suggestions for a connector with 15-17 pins 0.8-1.27mm pitch and locking mechanism? Thank you all already.
QDrives , 05-24-2024, 09:19 PM
You are forgetting one of the most important board to board spec/requirements: what (total) height between the boards.
If you mention "locking mechanism" there are 2 things:
1) What other mechanical mounting is between the 2 boards?
2) Positive? Friction? Screw?
Robert Feranec , 05-25-2024, 06:41 AM
I have used samtec for board to board connectors. also as @QDrives mentioned, you may need to add screws - that is one of the most standard solutions for these situations.
sheldor , 05-25-2024, 12:15 PM
my first solution was using double connectors to match them but it didn’t seem very solid. i didn’t use screws or something do you guys suggest that?
QDrives , 05-25-2024, 01:25 PM
We do not know what to suggest as we do not know what is required.
There are many thing to consider when designing electronic products. It is never just a PCB.
I would rarely trust on a board to board connector to make the only (mechanical) connection, unless you are talking about a piggyback type board.
sheldor , 05-28-2024, 06:24 AM
Thanks
