According to these images, which standard should be used to design the courtyard of electronic components? When should I use IPC-7351B, and when should I use IPC-7351C?
, 09-17-2026, 01:13 PM
🤖 In the meantime, here’s a response from the [FEDEVEL AI HW Assistant]().It helps to find relevant resources for your question, but it may make mistakes as it’s still in early development.This is the response from the AI Assistant:For courtyard design in component footprints, **IPC-7351C** is the current recommendation for new designs. Here's how to decide:1. **IPC-7351B (2005)** - Uses three density levels: • **Most** (hand soldering) • **Nominal** (standard SMT production) • **Least** (RF/analog designs) - Contains outdated courtyard rules where "most density" was later found ineffective for reliability in automated processes ([source](https://www.youtube.com/watch?v=cMxXea16Hxc&t=1576)) 2. **IPC-7351C (2017)** - Removed "most density" for automated assembly (now only for hand soldering) - Made courtyard calculations more practical using updated industry data - Aligns with modern manufacturing realities like 0201 components and ultra-fine pitch BGAs - Now classified as a *guideline* rather than a strict standard ([source](https://www.youtube.com/watch?v=cMxXea16Hxc&t=958)) **When to use which:** • **Use 7351C** for all new designs - it incorporates lessons from Japanese reliability studies and modern SMT lines • **Use 7351B** only if maintaining legacy designs where: - You need backward compatibility with old CAD libraries - Working with manufacturers still using 2005-era processes - Required by specific automotive/military specs frozen to B-revision Key difference: 7351C simplifies courtyard rules by eliminating redundant "most density" requirements while maintaining the core nominal/least distinction that works for 99% of modern designs ([source](https://www.youtube.com/watch?v=cMxXea16Hxc&t=3955)).You can continue chatting with the AI Assistant here:https://fedevel.com/hw-assistant
Robert Feranec , 09-18-2026, 05:46 AM
Has C been approved? Last time I think it was only a suggestion
QDrives , 09-22-2026, 07:58 PM
That is up to you.There is no mandatory element to the courtyard.A square courtyard is easy, the minimum one (as shown as version C) is much more work to create/draw.I only use the courtyard for documentation purposes and simply use a rectange.
QDrives , 09-23-2026, 06:20 PM
Footprint courtyard
