Robert Feranec , 04-23-2024, 01:22 PM
Saturn PCB can help and also, some time ago I created this video, can help too: https://www.youtube.com/watch?v=LQ20GBonRmA I would use saturn for some initial numbers, then build it as quickly as possible and then used thermal camera a measured the temperature. If needed, I would then adjust the stackup and PCB. If you use 4 layers, you can double the planes (route the same planes on multiple layers), but keep in mind, currents will not be spread equally, in my opinion it will be more like: the larger copper on output, better heatsink it will be.
