QDrives , 07-12-2024, 10:22 PM
It is not so much the number of layer for current, but the thickness of the copper and width of the traces.
By the way, a PCB does not "dissipate ... current", it dissipates heat, caused by current (I² * R). Easiest is to use a tool like PCB toolkit to get the width of the trace for a given thickness and temperature rise.
The number of layers is defined by the function/density/complexity of the board and if you want to use multiple layers for the current.
