IM73A135 Breakout Board Help
DestinyAwaits , 04-10-2024, 03:41 PM
Package is 0805 for all three Capacitors with Ceramic MCC SMD
DestinyAwaits , 04-10-2024, 03:49 PM
I still need a compatible Differential Amplifier and a 24-bit ADC because I don't think the ESP32 ADC is very good.
Sniper2 , 04-10-2024, 04:09 PM
what dielectric
Sniper2 , 04-10-2024, 04:10 PM
it is not , it is 12bit resolution but in practice 10 if i remember well
DestinyAwaits , 04-10-2024, 04:36 PM
X7R dielectrics
for both
Sniper2 , 04-10-2024, 04:39 PM
not great for audio since it buzzez
DestinyAwaits , 04-10-2024, 04:39 PM
Knowles 0805J0100104KXR for 100nFSamsung Electro-Mechanics CL21B106KPQNNNF for 10uF
Okay. Which one to choose then ?
CoG dielectric
Sniper2 , 04-10-2024, 04:40 PM
or electrolithic
want a open source reference design ?
DestinyAwaits , 04-10-2024, 04:40 PM
You can provide not sure If I will be able to understand or not
DestinyAwaits , 04-10-2024, 04:41 PM
I will still try to read
Sniper2 , 04-10-2024, 04:42 PM
https://github.com/immortal-sniper1/cross_band_handy_walkie_talkie
there
Sniper2 , 04-10-2024, 04:43 PM
it works
uses esp32 too + some code in there
DestinyAwaits , 04-10-2024, 04:43 PM
is there a way to find these capacitors in https://www.lcsc.com as I do not find them
Sniper2 , 04-10-2024, 04:46 PM
https://www.lcsc.com/products/Aluminum-Electrolytic-Capacitors-SMD_418.html or https://www.lcsc.com/products/Multilayer-Ceramic-Capacitors-MLCC-SMD-SMT_313.html with COG filter
LCSC/JLC filters are on page not in URL so u need to filter localy
DestinyAwaits , 04-10-2024, 04:50 PM
Package: 0805Voltage: 10VTolerance: +- 10%Capacitance: 100nF and 10uFNow Temperature Coefficient disables COG
Please try
Sniper2 , 04-10-2024, 04:53 PM
COG should be stable
try without temp
LCSC filters are bad anyway
DestinyAwaits , 04-10-2024, 04:53 PM
digikey ?
Sniper2 , 04-10-2024, 04:55 PM
https://github.com/yaqwsx/jlcparts
DestinyAwaits , 04-10-2024, 04:58 PM
Updating component library
DestinyAwaits , 04-10-2024, 05:00 PM
I will let you know what I find.Thank you for today. It will take time for me to understand it more. I can say not even close to fabrication step. 🙂
Sniper2 , 04-10-2024, 05:00 PM
i can see
Sniper2 , 04-10-2024, 06:02 PM
so?
do u get it?
QDrives , 04-10-2024, 07:19 PM
You will not find 100nF or 10uF in C0G.Best is to use electrolytic (polymer) or tantalum. You can add a local C0G for the high frequency (1...10nF).
Sniper2 , 04-10-2024, 07:34 PM
true
DestinyAwaits , 04-11-2024, 01:34 AM
Did not find COG. Now am not sure if package 0805 is correct or not for both 10uF and 100nF?If possible for both of you can you provide the parts I should use? Finding it difficult to search the right parts. The mems microphone max supply is 3V and I will pair this with 3.3V ESP32 that is why I chose 10V. Can you please share if not links but direct part number to search will be really helpful. 🙏
Sniper2 , 04-11-2024, 04:09 AM
Use lectrolithic
@DestinyAwaits
Sniper2 , 04-11-2024, 04:10 AM
Ps since the audio ends up in a adc / codec you will not care so much about voltage anyway
DestinyAwaits , 04-11-2024, 04:47 AM
@Sniper2 bro can you share the part number searchable on LCSC or any other site? Like I shared earlier as below?Knowles 0805J0100104KXR for 100nFSamsung Electro-Mechanics CL21B106KPQNNNF for 10uF
Sniper2 , 04-11-2024, 03:02 PM
It is in my kicad project
@DestinyAwaits
What can't u find?
DestinyAwaits , 04-11-2024, 03:18 PM
I haven't gone through the project yet. Let me check the BOM file to find the capacitors. Thank you @Sniper2
DestinyAwaits , 04-11-2024, 04:29 PM
@Sniper2 the bom in project for one capacitor was using X7R only not COG I checked the part C1466350V 100nF X7R ±10% 0603 Multilayer Ceramic Capacitors MLCC - SMD/SMT ROHS
Sniper2 , 04-11-2024, 04:37 PM
ok
QDrives , 04-12-2024, 03:45 PM
Pick one from the listhttps://www.digikey.nl/en/products/filter/aluminum-polymer-capacitors/69?s=N4IgjCBcoGwJxVAYygMwIYBsDOBTANCAPZQDaIALAAxwDMdIAuoQA4AuUIAymwE4CWAOwDmIAL6EATFQoJoIFJAw4CxMuCoACAK0AxEITCSd%2BwwFYTB8AA5LU43quSA7HZC1ab%2Bm4qvHhMxg3GFt-EGsHUw0tR2YQdk4AVUF%2BNgB5VABZXHRsAFdeXHEpKmc5ZDQsPEISSHIYADpPADUrW1bDSQaLDvBjXrAtAaDWuITIEGTUjOzcgqKJEABaSUQFKD481VryBACmRaXaNcVN7fVBg8Il8vXIM5qLg8WYNf4AE04lwYhWDgmrGwAJ4sIoTXIoMRiIA
DestinyAwaits , 04-14-2024, 10:01 AM
@QDrives okay. Thank you. I am checking now.
Sniper2 , 04-16-2024, 07:06 PM
@DestinyAwaits progress?
DestinyAwaits , 04-17-2024, 08:53 AM
@Sniper2 I got in touch with Infineon to get the help related to the data. Once I get concrete answers I will update.
