Mosfet gate driver as PWM level shifter
Anik , 10-25-2024, 10:46 AM
HI, Is it possible to use Mosfet gate driver as a PWM level shifter. I need 3.3V pwm from microcontroller to 10V pwm signal for a LED driver which requires 10V pwm. I was wondering to use MCP1416 (https://www.lcsc.com/product-detail/Gate-Drivers_Microchip-Tech-MCP1416T-E-OT_C83775.html) for it. Will it work??Thank you.
QDrives , 10-26-2024, 12:12 AM
It might. Thing is, we do not know the input of your LED driver....
Anik , 10-26-2024, 04:51 AM
just need 10V PWM signal by 0%, 10%, 20%...... 100% duty cycle for brightness and current does not matter cause 20mA is enough.
QDrives , 10-26-2024, 07:41 PM
"*...to 10V pwm signal for a LED driver...*" -- So is the gate drive **the** LED driver, or is there another driver that needs 10V PWM input? The way you have written is, implies the second."*...cause 20mA is enough.*" -- That sounds like the date driver **is** driving the LEDs.Do note that this gate driver does not have over current, short circuit nor over temperature protection.
Anik , 10-29-2024, 03:49 PM
This is the LED driver datasheet. The datasheet says the pwm input is isolated on the first page and page 6 and 13 has other information about PWM. But dont have enough information about current
QDrives , 10-29-2024, 09:18 PM
The datasheet does state:"*Source Current on Vdim (+)Pin 90 uA 100 uA 110 uA Vdim(+) = 0 V*"Do note that my comments on the MCP1416T still stand:"*Do note that this gate driver does not have over current, short circuit nor over temperature protection.*"So if a short circuit is made in connecting while powered, it probably will damage your driver.
Anik , 10-30-2024, 05:09 PM
Ok then. Maybe the 10K or more resistor can prevent this issues.
QDrives , 10-30-2024, 08:23 PM
Well, a 1206 1k resistor would be better. It can then drive up to 12mA. And a slight overload if shorted (144mW compared to standard 125mW).
Anik , 12-05-2024, 06:52 PM
This one worked perfectly with 1K and shorted as well. Thanks.
