Robert Feranec , 01-18-2024, 05:36 AM
this is tricky. even if you find one specific display which would fit your need, question will be if you still don't want to use a standard display + a carrier/adapter board which you would design. if this is only to build 1 board, special display will be fine, if you would like to manufacture it in bigger quantities, standard display + adapter may be a better solution. But to answer your question directly, I don't know that kind of display, but I often try on amazon to find some unusual hardware from china.
