STM32m257F DFU doesn’t work
SergenX , 04-17-2026, 07:36 AM
Hello I designed a SoM board for my system but I faced some problems I can’t see DFU on the stm32cubeprogrammer also I pulled down to gnd all boot pins.I dont programmed the stpmic25 its could be? or diffirent.My schematics
Robert Feranec , 04-17-2026, 08:26 AM
some STM have a fuse that needs to be set to use the pin to be able to go into DFU. Have a look at nBOOT_SEL
SergenX , 04-17-2026, 09:25 AM
Thanks for your comment 🙏 I will check it
SergenX , 04-17-2026, 11:27 AM
I didn’t see nBoot_sel in the datasheet also I comparated discovery board and my som board the my board nrst ,pwr on and pwr cpu on pins always stay 0 ı pulled up to 3.3v with 10k resistor but doesn’t change anything
Robert Feranec , 04-20-2026, 06:13 AM
use STM32CubeProgrammer to check the status of the bit
Robert Feranec , 04-20-2026, 06:14 AM
I don't know why it stays 0 there may be multiple reasons
SergenX , 04-23-2026, 05:57 AM
Hello , I resoldered the MPU now the usb coming on the device manager but its gives code 43 USB Device Not Recognized error I will try with stlink v3 thank you so much for your support.
