TCRT5000, breakout board or single piece?
jotaro , 05-07-2026, 05:40 PM
I am looking for a cheap andn low range solution to detect presence interrupt a microcontroller to wake it from sleep mode and my research led me to this part, which is a reflective infrared emitter/collector sensor. However, I see it sold as a breakout and a single piece itself, refer to the imagesI think the single piece itself should be able to detect and output a signal even without all those extra parts present on the breakout board right? I am not sure where to look to confirm this 100%
, 05-07-2026, 05:43 PM
🤖 In the meantime, here’s a response from the [FEDEVEL AI HW Assistant]().It helps to find relevant resources for your question, but it may make mistakes as it’s still in early development.This is the response from the AI Assistant:The TCRT5000 infrared sensor can be used as a standalone component, but you'll need to add external circuitry to make it functional for microcontroller wake-up applications. Here's the breakdown:1. **Core Functionality** The TCRT5000 itself contains only the IR emitter and phototransistor - it needs external resistors to operate:- Current-limiting resistor for the IR LED (typically 100-200Ω)- Pull-up resistor for the phototransistor output (value depends on your detection range needs)2. **Breakout Board Advantages** Pre-made breakouts typically include:- Optimized resistor network- Comparator circuit for clean digital output- Power filtering capacitors- Status LED indicators3. **Wake-Up Implementation** For sleep mode applications:- The raw sensor output is analog (varies with reflection distance)- You'll need either: - A comparator circuit (like on breakouts) to create digital interrupt - Microcontroller ADC with threshold detection in firmware4. **Design Tradeoffs** - **Standalone**: Cheaper but requires PCB space for support components- **Breakout**: More expensive but plug-and-play with digital outputExample from similar designs: A battery management module used standalone sensors but required external pull-ups and filtering ([Source](https://www.youtube.com/watch?v=dHi4b9t5NYw&t=2030)). Breakout boards simplify this by integrating support components.Recommendation: If you're space-constrained or need reliable digital triggering, use the breakout. For lowest cost and have PCB space, use the standalone with 2 resistors and a comparator (if needed).
Always verify with the sensor's datasheet for specific resistor values.You can continue chatting with the AI Assistant here:https://fedevel.com/hw-assistant
QDrives , 05-07-2026, 09:26 PM
The part is "analog". An interrupt is digital.You need to make the conversion.
jotaro , 05-07-2026, 11:22 PM
what would I need to convert the AC to DC if not using the breakout
Robert Feranec , 05-08-2026, 06:58 AM
this looks like the schematic: https://easyelecmodule.com/tcrt5000-infrared-reflective-sensor-how-it-works-and-example-circuit-and-code-based-on-arduino/
jotaro , 05-08-2026, 10:01 AM
i only understand that the blue led that emits the IR has a current limiting 180 ohm and the collector led has 10k pullupbut i dont know what that op amp does or its inputs like that "VR1" thingi think the op amp is acting as a rectifier? how does that work
QDrives , 05-08-2026, 11:23 AM
Did you read the text in the link provided by Robert?The schematic has a comparator, not op-amp. Same symbol, but (slightly) different function.A comparator is turning an analog signal (compared to a reference -- VR1) into a digital signal.AC = Alternating CurrentDC = Direct CurrentThat is not "Analog" and "Digital"
jotaro , 05-08-2026, 11:33 AM
it mentioned op amp here
jotaro , 05-08-2026, 11:34 AM
so that 10k resisotr at vr1 is a pull down right, does the comparator work by comparing the voltage at the phototransistor relative to the ground and output a fixed DC signal?
QDrives , 05-08-2026, 02:58 PM
The LM393 is a comparator, not an op-amp. It also states that.https://www.electronics-tutorials.ws/opamp/op-amp-comparator.htmlVR1 does not have a pull-down, nor pull-up. Is is between Vcc and Gnd. A 10kΩ trimpot.
jotaro , 05-08-2026, 02:59 PM
oh so that's what VR is
variable resistor = trimpot
QDrives , 05-08-2026, 03:01 PM
Trimming potentiometer or trimpot.https://www.digikey.nl/en/products/filter/trimmer-potentiometers/80
jotaro , 05-08-2026, 03:01 PM
isnt a comparator a type of op amp
that is what I am understanding from the wording
op amp is general
QDrives , 05-08-2026, 03:02 PM
You can make a comparator from an op-amp (limits apply).
jotaro , 05-08-2026, 03:03 PM
so what does that variable resistor do mathematically with that comparator
the wiring is confusing me what is this resistor here for after the comparator
jotaro , 05-08-2026, 03:04 PM
i think it is a pull up?
i assume every piece here is connected to vcc
QDrives , 05-08-2026, 03:05 PM
The LM393 has an open collector output. Hence you need a pull-up.
Yes. All dots.
jotaro , 05-08-2026, 03:08 PM
after some chatgpt, that VR trimpot seems to be the adjustment for the "hysteresis" of the amp
jotaro , 05-08-2026, 03:09 PM
this the formula
r1 must be 10k at the non inverting and r2 must be the trimpot
QDrives , 05-08-2026, 03:10 PM
Not hysteresis, but the 'setpoint'.There is no hysteresis in this design.
jotaro , 05-08-2026, 03:12 PM
is there no feedback
thats what the trimpot is for isnt it
QDrives , 05-08-2026, 03:12 PM
Not realy.Here it is much simpler: just compare two voltages. The one given by the TCRT5000 and the one set by the trimpot.
QDrives , 05-08-2026, 03:13 PM
No feedback. Rarely used with a comparator.
jotaro , 05-08-2026, 03:14 PM
wait let me draw
jotaro , 05-08-2026, 03:16 PM
is this what the op amp circuit looks like
jotaro , 05-08-2026, 03:17 PM
what do the resistors at the + and - do
jotaro , 05-08-2026, 03:18 PM
well i forgot to draw gnd for the - side
but it should be there
jotaro , 05-08-2026, 03:19 PM
or i could be misunderstanding
QDrives , 05-08-2026, 03:35 PM
Yes, you are misunderstanding.Learn more about comparators, potentiometers and transistors.Or buy the breakout board and play with it.
jotaro , 05-08-2026, 06:41 PM
jotaro , 05-08-2026, 06:42 PM
the op amp compares the voltage entering into + with the voltage at -and the variable resistor/potentiometer is basically a voltage divider internally right so it will allow me to adjust the voltage entering -the op amp will output vcc on the right side when + is more than -
did i get this right
QDrives , 05-09-2026, 05:12 PM
A "comparator" compares.An op-amp amplifies the difference. With feedback you control how much the amplification is. Remove that feedback, and it will drive either - or +. In a sense creating a comparator.For the rest your text is correct.
jotaro , 05-11-2026, 09:19 PM
what is the resistor at + side for? can it just connect to vcc without?
QDrives , 05-11-2026, 11:23 PM
"*can it just connect to vcc without?*" - if you want a smoke machine.The sensor controls current. A comparator needs voltage.
