Will this provide near field magnetic coupling
Shoaib Mustafa , 06-18-2026, 08:18 PM
Hi. I am designing a circuit for driving a large loop for magnetic coupling with a reader. I've calculated and ran a few simulations. in all the results the answer can back to use a capacitor of 97nF considering that my loop (rectangle single wound) is about 16uH. Please ignore the capacitor value in this image. i miscalculated here. I'd just like to know if it will actually achieve resonance with this and provide near field coupling to an appropriate reader? i've never designed such a system so finding it hard to trust just the equations without any advice from someone who's tried it.
, 06-18-2026, 08:23 PM
🤖 In the meantime, here’s a response from the [FEDEVEL AI HW Assistant]().It helps to find relevant resources for your question, but it may make mistakes as it’s still in early development.This is the response from the AI Assistant:Based on the video content, here's what you need to consider for your magnetic coupling design:1. **Resonance Fundamentals**: Your 16μH loop with 97nF capacitor creates a resonant frequency of ~127kHz (using f=1/(2π√(LC))). This falls within typical near-field communication ranges (125-134kHz), so the math checks out. [Relevant LC resonance discussion](https://www.youtube.com/watch?v=J4UUGSIP770&t=2559)2. **Parasitics Matter**: Real capacitors have equivalent series inductance (ESL) that affects resonance. A 97nF ceramic capacitor in 0402 package has ~0.5nH ESL, which would shift resonance frequency slightly. Ensure your simulation includes these parasitics. [Capacitor parasitics explanation](https://www.youtube.com/watch?v=J4UUGSIP770&t=2735)3. **Coupling Efficiency Depends On**: - Loop area (larger = better coupling) - Alignment with reader coil - Quality factor (Q) of your resonant circuit - Distance between coils4. **Practical Verification Steps**: - Use vector network analyzer to measure actual resonance - Check field strength with near-field probe - Experiment with capacitor values ±20% to account for parasitics - Consider using multiple smaller caps in parallel to reduce ESL[Example of resonant circuit analysis](https://www.youtube.com/watch?v=Tt8X6_maj6c&t=1932) shows how component interactions affect actual performance.While your calculations appear correct, successful magnetic coupling requires careful physical implementation.
Start with prototype testing at varying distances (1/4 wavelength rule doesn't apply in near-field), and monitor the reader's response during tuning.You can continue chatting with the AI Assistant here:https://fedevel.com/hw-assistant
QDrives , 06-19-2026, 10:52 AM
You only show half of the circuit and no details on the IC.
Shoaib Mustafa , 06-20-2026, 09:59 AM
Oops. i'm sorry. The IC the h bridge driver DRV8837
