robertferanec , 10-25-2019, 05:16 AM
In most of my boards (processor boards), I connect it directly to digital GND, but there are situations where you may need to connect it differently ...
For example in other cases it can be connected to Enclosure GND or sometimes there may be additional circuit ... the connection may depend if you are connecting two devices which are powered through different main power plugs, if devices are long way from each other (e.g. currents may flow then between devices through this GND) .. or it can depends on if one of the devices is powered from battery or if you are using plastic / metal enclosure or if you are (not) using transformer in power adapter ... there is no one answer.
If you are not sure, provide more options to Fit / Unfit different combination of components and during testing you will find the proper connections for your specific system.
