Comunication Tracks
Brunodrt , 01-09-2021, 08:35 AM
Hello All,
Would there be any advantage on having a GND trace for example between the microcontroller and the CAN transceiver signals ( signal with frequencies higher then 20kHz for example )? Or should I make sure to have the signal on the outside on the signal and not between them ?
Thanks
Best Regards,
BD
Brunodrt , 01-09-2021, 08:40 AM
To be noted that this is a 4 layer board and bellow this signal layer there is a GND plane
robertferanec , 01-11-2021, 02:10 AM
Normally I do not route GND tracks on signal layer (occasionally there can be an exception e.g. around crystal or oscillator). However, what is important, I always try to make the clearance between neighbor tracks as big as possible. And I have not seen any problems with this technique.
ibocakir06 , 01-30-2021, 12:02 PM
Yoda’s advice applies just as well to some aspect of circuit board design as it does to mastering the Force. There are many myths and myth-conceptions about ...
If you pay attention to Mr. Bogatins advice, you shouldnt place a gnd around traces. You only need to do is seperating traces between each other.
