@kazemiy974 I would recommend to have a look how PCB is manufactured, that will help you to answer your questions. Have a look for example at video:
https://youtu.be/67WhV0EDqCAUnderstanding PCB manufacturing process will answer some of your questions. For example drilling. To build the stackup on your picture ... that may actually not be possible.
For example, Core is a 2 layer PCB: copper + izolation + copper = core. I guess it could be possible to have 1 layer core (I have not heard about it, but maybe it exists) and then you could do: Copper+izolation+prepreg+copper ... but ... I am not really sure.
The same for drilling. How would you drill 3 to 5? Standard drilling is always through hole, means, they drill through the whole PCB. If you would want to drill from 3 to 5, theoretically you could do it, but you would have to build this section first, drill it and then glue it with the other parts of your PCB. However in this case you could not have any buried vias ending or starting on layer 4, because how this would be manufactured?
I recommend to watch the video.
