1) Both Line and Neutral are primary side. I assume that the DC part are secondary?
Do note that in most cases, neutral CANNOT be considered as 0V, so consider line and neutral to be swapped. If I remember correctly, only large fixed installations may consider Line and Neutral to be connected (applied) correctly.
Old rules in Europe: 3mm when PE is used (class I device) and 6mm for double isolation (class II)
Perhaps these will also help:
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/188/Clearance-and-creepage_5F00_UL_2D00_60950_5F00_IEC_2D00_60950.pd fhttp://www.creepage.com/clearance_perl.htm
https://electronics.stackexchange.com/questions/22796/creepage-distance-for-pcbs-handling-line-voltage-acQuestion is also:
- Which country, countries or continents
- Type of application: residential, (light) industrial, medical, fixed or portable, machine / appliance / IT / etc.
2) Talk to a fabricator on this topic and add a note in the documentation (that they receive as well).
3) So it is hot (voltage wise) ! There are ways to insulate it.
4) Yes, that is correct.
5) Yes, thermal relief will reduce current. But the question is - will it be to much?
Or perhaps even a better question is - how much? This answer if often -- very little.
6) I did not mean transparency for the 3D model, but transparency on the copper layers. 3D layer can be hidden completely.
