I have a PCB project where my PCB have to be interface between 3 systems. And because cables from battery are long and full of noise, we decided to separate grounds on PCB and to take ground from S1 and ground from S2 as reference for analog voltage (isolated DAC).
For connection between systems and MY PCB we use standard M connectors with shielding.
Of course, more than one ground more problems.
Problem is with shielding and ESD (one board passed one failed ... )
PCB is in plastic housing.
In first scenario all connectors shielding are connected to corresponding ground. For example connector for system S1, shield is connected to the ground of S1. And so. But, when S1 is not connected, gnd floating. Same for S2. Please check figure:
In this first scenario when every connector has corresponding GND to shield, ESD caused failure of one PCB. And S2 wasn't attached (somehow one pin of MCU is short and that pin doesn't goes outside of PCB, we couldn't repeat this on second PCB)
Second scenario is that all shields of connectors are connected to minus line of battery.
Third scenario is that all shields are not connected.
I saw a video:
https://www.youtube.com/watch?v=F9tB6JtG7oQ But what when housing is plastic?
On the o side of systems S1 and S2, shield is not connected. Battery voltage is 24V
What would be the best way to connect shielding ? Or to put zero ohm bridge and to test
TY
