Does it means it draws maximum 100mA current per pin
@sneha.xeye, have a look at the circuit what is inside the chip. There is nothing else only diodes and inductors (magnetics):
The chip doesn't draw any currents. Currents simply flow between pins 1<->10, 2<->9, 4<->7, 5<->6. The lines between these pins (e.g. the physical connection inside the chip between pin 1 and 10) are probably very thin, so maximum current which can run trough the lines inside the chip is 100mA. If you try to run higher current between pins 1-10, you will probably damage the connection.
