- 150mA is not much, but still try to see if there is no component getting warm or hot (use your fingers or use alcohol - e.g. see Louis Rossmann's video
https://www.youtube.com/watch?v=t5fICjcaJ3E )
- I am not sure how you measured the short circuit (e.g. if you used diode measurement or resistance measurement), but I would use DVM (Digital Voltmeter) to measure resistance between individual powers and GND. Be careful, sometimes it may look like a short circuit, but it doesnt have to be (e.g. if there are protection diodes - including the diodes inside chips, or some chips have very low impedance termination, ....). It may also depend how you connect DVM, try to swap the probes (if you measured VCC by RED probe and GND by BLACK, try to measure VCC by Black and GND by RED) - just to make sure, that what you are measuring is direct short circuit e.g. you measure resistance 0.1OHM
- another option is to check Power OK signal of the regulators (but this depends what kind of chips you are using, some chips do not have power ok pins)
- or I would start building another board, but step-by-step ... fit the first regulator, measure if everything is ok, then another one, another one ... etc
PS: The problem can be something completely different and not power supply (I am not sure what everything is on your board and what is connected to your board)
